Transmitting Data From Your EL-WIFI Series Data Logger
There’s been some confusion with with regard to EL-WIFI series data loggers and the way that they transmit temperature & humidity data back to the PC.
In order for an EL-WIFI series logger to remain connected and continually transmitting data, the logger must be in range of the wireless router, with the EL-WiFi Sensor Software running. If for any reason the EL-WiFi Sensor Software stops running, or if the EL-WIFI logger goes out of range of the wireless router, data will be buffered internally until the wireless connection is re-established and the software is running once again.
If the EL-WIFI logger goes out of range of the wireless router while the software is running, the status will change to ‘Not Connected’.
Transmitting data from your EL-WIFI Series Instrument.
Once the EL-WIFI logger comes back in range of the wireless router, the status will remain ‘Not Connected’ until the logger attempts to transmit data.
The time period between data transmissions (how often the device will attempt to communicate with the PC) is chosen by the user during configuration.
You can force the EL-WIFI logger to reconnect (before the next attempted data transmission) by pressing the pushbutton three times, displaying WiFi signal strength. Note that it may take a few seconds for the status to change to ‘Connected’ in the software.
When the connection is re-established, the logger will sync with the PC and transmit any buffered data the next time it tries to communicate.
With the software running and the EL-WIFI logger in range of the wireless router, the ‘Next Reading’ progress bar gives a visual indication of when the next data transmission will occur.
Note too that any changes to device settings will not take effect until the forthcoming data transmission occurs.
 Categories: Configuration, Data Logger, Temperature and Humidity Data Loggers, Wireless Data Loggers
 Tags: , ,
3 Comments
  1. Avatar
    Ron Rothstein
    Posted July 22, 2015 at 11:30 am Permalink
    My wireless network has 256-bit WEP security. Can your sensors operate and transmit data in this environment?
    • Posted July 30, 2015 at 2:19 pm Permalink
      Hello Ron,
      Yes, EL-WIFI series loggers will operate and transmit data on a network with 256-bit WEP security. You will need to provide the password as part of the initial configuration.
      Regards,
      Shawn MacDonald
      Application Engineer
      DATAQ Instruments Inc.
  2. Avatar
    Richard
    Posted August 10, 2016 at 1:22 pm Permalink
    Will this connect with WPA2-Enterprise security protocol where Username+Password is required?
    Thanks
