DI-245 .NET Programming Example
We’ve released a new programming example for the DI-245 four-channel USB Voltage and Thermocouple DAQ  that uses the Simple version of the interface to configure all aspects of the instrument.  The example allows any channel to be configured for either thermocouple or voltage measurements. If programmed for voltage it allows any of the 12 selectable ranges to be programmed per channel. If programmed for TC measurements any one of  eight TC types can be selected per channel. Any channel can also be disabled. Other programmable elements are sample rate and digital input channel. With that, all programmable aspects of the DI-245 are accessed in this single example program.
DI-245 .NET Example App
Operationally the VB.NET program allows you to configure a particular data acquisition setup, and then begin continuously scanning. Output is a text display in calibrated units. The program uses an efficient event trigger and handler routine to display in real time at the fastest DI-245 sample rate, so it represents an excellent foundation on which to build your own applications. And the .NET architecture easily transfers from VB to C# or any other .NET programming environment. Finally, the application is well-commented so you can easily grasp the essentials of DI-245 programming.
Download links follow:
Zipped DI-245 .NET Programming Example
 Categories: Data Acquisition, Programming
2 Comments
  1. Posted February 28, 2017 at 7:31 pm Permalink
    Has anyone changed the code?
